1. AC Question's Avatar
    I have samsung S5 kernel ver. Sm 900. My problem start when I encrypted my sd card as i enable my encryption every time i open my device it ask for alternate passwork every time i enable and disabled it which is normal. When i get home and use my home wifi, my phone system update automaticaly then as i enter my alternate password in my device it seems not working anymore i tried. I check my phone status and it still in kernel ver and all status are desame. But its seems every time i tried to enter my alternate password its not working anymore and putting any sd card on my phone would not work either. I do hope is some one knows solutions for this kind off problem.
    05-05-2016 12:42 AM
  2. Claude Speed's Avatar
    Don't use SD card encryption because it is a proprietary feature
    05-05-2016 01:17 AM
  3. Rukbat's Avatar
    Or make sure that everything on the card is backed up, so in a situation like this you can format the card and copy everything back.
    05-13-2016 12:16 PM
  1. Emoji plugin that works with Kii Keyboard?
    By Lacey_Underalls in forum Samsung Galaxy S7 edge
    Last Post: 11-01-2016, 12:02 AM
  2. is the international version on MM And will it work properly on AT&T?
    By ekerbudeeeek in forum Samsung Galaxy Note 5
    Last Post: 05-13-2016, 12:17 PM
  3. Google now not working
    By maverick7526 in forum Nexus 6P
    Last Post: 05-05-2016, 04:33 PM
  4. How can I fix some video app problems?
    Last Post: 05-05-2016, 03:00 AM
  5. Replies: 0
    Last Post: 05-04-2016, 07:00 PM
