1. curtqn02's Avatar
    I'm a newbie. Just got an Verizon GSM unlocked Samsung S5. I'm using it with T-Mobile. It work fine. Only a couple problems:
    1) When I get a voice mail. There is no sound, no notification on my phone. When I dial my number and input the password the phone keep saying "Enter your password". If I keep doing it for a while. Sometimes I can get it. Sometimes not.
    2) I check for update. It says "no update available". Is there a safe way I can update my phone software and still keep it unlocked and not brick it.
    Thanks.
    06-10-2016 11:41 PM
  2. Lilybell2's Avatar
    Presumably your S5, as you purchased it from Verizon, is a carrier branded phone, the G900V. Your problems may stem from having APN settings that were right for Verizon but wrong for T-Mobile. T-Mobile can tell you if your APN setting are correct. If not, they can assist you with changing to the correct APN settings, which isn't difficult to do.
    You may be getting the "no update available" message as your phone is most likely running Verizon's customized version of Android, which is intended to be updated OTA on the Verizon network.
    ironass likes this.
    06-11-2016 12:26 AM
  3. curtqn02's Avatar
    Set up APN again. It works fine
    Thanks a lot
    06-12-2016 04:27 AM
  4. Lilybell2's Avatar
    You're very welcome. I'm glad I could help.
    06-12-2016 01:22 PM
  1. aptX with bluetooth?
    By redsandvb in forum Nexus 5X
    Last Post: 06-10-2016, 11:31 PM
  2. Replies: 1
    Last Post: 06-10-2016, 11:13 PM
  3. samsung note 3 startup wizard rooted with yemmen
    Last Post: 06-10-2016, 10:55 PM
  4. Critical Custom OS problem
    Last Post: 06-10-2016, 10:38 PM
  5. Replies: 1
    Last Post: 06-10-2016, 10:25 PM
