1. Castle Rock's Avatar
    Ive had my phone for almost 2 years now and the battery drains much faster than it ever used to. At times the phone gets very hot.
    Could this just be because its a few years old now?
    My phone also seems to be running much slower than it ever used to!!
    I installed the clean master app, this helps to remove junk files etc... but doesnt seem to make a difference in terms of battery saving/speeding the phone up.
    Is the clean master app still good to have? I removed suggested junk files. im not even sure if I should be following that advice tbh :-/
    06-12-2016 05:48 AM
  2. combat82's Avatar
    It's likely because the 6.0 update, you're not the only one.
    06-12-2016 07:48 AM
  1. Replies: 1
    Last Post: 06-13-2016, 04:45 AM
  2. Battery went from 80 to 0 immediately
    By vfp5 in forum Samsung Galaxy Note 5
    Last Post: 06-12-2016, 08:39 PM
  3. Backing up my phone
    By Castle Rock in forum Samsung Galaxy S5
    Last Post: 06-12-2016, 10:04 AM
  4. Samsung tablet magnetic cover kills mobile phone battery?
    Last Post: 06-12-2016, 09:01 AM
  5. Replies: 1
    Last Post: 06-12-2016, 06:45 AM
