1. Sofronea Gabriel's Avatar
    I recently reseted my phone to factory settings and my data does not work again
    This happend when i got here but a friend fixed it in 1 minute
    I know it is something easy but i dont know what it is
    Thank you
    06-12-2016 07:05 AM
  2. ironass's Avatar
    Thank you
    Hello and welcome to Android Central Sofronea Gabriel!
    Which model of Galaxy S5 mini do you have? Go to Settings > About device > Model number.
    Are you using a U.S. or U.K. sim card in the phone? Your APN settings may need changing depending on the network you are using.
    06-12-2016 11:21 AM
  3. Sofronea Gabriel's Avatar
    SM-G800H
    i am using a UK sim card / lycamobile
    06-12-2016 11:36 AM
  4. ironass's Avatar
    SM-G800H
    The U.S. model of the S5 mini, G800H, is not compatible with the U.K. 4G/LTE network on LycaMobile UK. So in Settings > Mobile network settings > Preferred network type... you set it to 3G. Also, ensure that you have the LycaMobile UK settings selected in Access point names.
    06-12-2016 12:11 PM
  1. Replies: 1
    Last Post: 06-13-2016, 05:45 AM
  2. Replies: 1
    Last Post: 06-13-2016, 05:44 AM
  3. Battery went from 80 to 0 immediately
    By vfp5 in forum Samsung Galaxy Note 5
    Last Post: 06-12-2016, 09:39 PM
  4. could not do normal boot (ODIN MODE)
    By Tan1117 in forum Ask a Question
    Last Post: 06-12-2016, 06:46 AM
  5. Unable to use Horizontal text in snapchat
    Last Post: 06-12-2016, 06:27 AM
