1. Jatzbak's Avatar
    Hi,
    We have a Samsung S5 Neo that has started showing a white triangle pointing downwards just above the clock in the very top right corner of the screen.
    Any one have any ideas what this means. I've tried searching the various forums, but can't find any info on this.
    Any help would be great, thanks.
    White triangle pointing downwards in top right corner above the clock - Samsung S5-screenshot_2016-06-21-10-06-15.jpg
    06-21-2016 04:25 AM
  2. H3aTeRzz's Avatar
    Hi
    No idea. Can you snap some screen shot(s) of your running processes? Might be able to spot it there, if its actually a process and not part of your launcher....which brings me to ask, do you have a 3rd party launcher active? Try changing the wallpaper too, just a hunch.
    Chris
    Jatzbak likes this.
    06-21-2016 06:15 AM
  3. Jatzbak's Avatar
    Changing the wallpaper has fixed the problem The pic was a screenshot this user had taken and the triangle was in the screen shot. Doh! I've got them to put a different wallpaper on now.
    Many thanks for your help.
    H3aTeRzz, ironass and Tritonemusic like this.
    06-22-2016 04:43 AM
  4. H3aTeRzz's Avatar
    Glad you got it figured out! Don't hesitate to call on us again, if you need assistance, we're here to help!
    Chris
    06-22-2016 07:28 AM
  1. Replies: 1
    Last Post: 06-28-2016, 03:01 AM
  2. Samsung Galaxy S2 T813N w/ Android 6.0 Marshmallow
    By sharpdroid in forum Samsung Galaxy Tab S2
    Last Post: 06-22-2016, 08:31 PM
  3. How is gaming on the OnePlus X?
    Last Post: 06-21-2016, 02:17 AM
  4. Replies: 0
    Last Post: 06-21-2016, 01:23 AM
  5. S6A audio jack no longer working after being in water?
    Last Post: 06-21-2016, 01:21 AM
