1. IMANUT46's Avatar
    Suddenly, when I scan multiple page documents, I don't get the option to scan another page. In other words, I have to individually scan each page. What's the fix. Thanks.
    Samsung Galaxy S5 Marshmallow 6.0.1 Verizon
    07-03-2016 05:41 PM
  2. ironass's Avatar
    Just to clarify... do you mean the ePrint app for Hewlett Packard printers?
    HP Printers - Using the HP ePrint App
    07-03-2016 05:50 PM
  3. IMANUT46's Avatar
    Yes, but the All-in-One Remote is the app that doesn't work.
    07-03-2016 06:23 PM
  4. IMANUT46's Avatar
    I installed the above printer that is used exclusively for my Samsung Galaxy S5-Verizon Edition. There is no PC, Laptop involved. I'm able to print and scan, although the scanning and printing involves switching back and forth between wifi connections.
    I see the option for WiFi Direct. What exactly is the difference, and why would I want to do it? Thanks.
    07-10-2016 01:55 PM
  5. can3gxw's Avatar
    WiFi direct means that the printer itself acts like a hotspot. You connect to the printer itself using ITS connection, not your home WiFi.
    If your printer supports web printing/scanning, just set that up instead.
    07-10-2016 02:05 PM
  6. IMANUT46's Avatar
    Thanks.
    07-10-2016 05:28 PM
  7. IMANUT46's Avatar
    This printer will not* scan multiple pages *so that I can assembl*e into 1 document. My* older hp 3520 would *ask if there were mor*e pages to scan. What*'s wrong and is there* a workaround.
    This question was posted to HP's site, but I've not received a response.
    Thanks*.
    07-12-2016 08:46 AM
  8. mstrblueskys's Avatar
    Thanks*.
    Not sure this is the right forum for that question.
    Check and see if there's a software update. Are you using your phone or your computer?
    07-12-2016 09:07 AM
  9. IMANUT46's Avatar
    I just upgraded to Marshmallow 6.0.1. I'm using a smartphone.
    07-12-2016 09:28 AM
  10. can3gxw's Avatar
    You will need to check the manual for that specific printer and see how (or if) it can be done. Most apps will have the scan feature for these types of printers, but some may not.
    07-12-2016 10:15 AM
  11. IMANUT46's Avatar
    I've gotten a little further along with the setup of this printer. I was able to get an email address for the printer, but it won't accept any entry. I tried the wifi password and my regular email password. None works. Any other suggestions. Thanks.
    07-13-2016 10:22 AM
  12. can3gxw's Avatar
    It's a brand new printer, just call HP and ask them for help. You won't find the help you need on an Android forum.
    HP Technical Support, Help, and Troubleshooting | HP® Customer Support
    07-13-2016 04:36 PM
  13. IMANUT46's Avatar
    That's a great tip. I've tried using the site but I can't seem to be able to submit my problem. Is there a Chat line that I can use to speak to a live technician to help me? Thanks.
    07-13-2016 07:31 PM
  14. IMANUT46's Avatar
    After 30 minutes on the phone with an incoherent Tech person, I gave up. I asked for an email address so I could communication my problems in writing. All I got was their support site which is useless for me. The biggest problem is printing photos. The printer will not let me set the photo size. It will print only on full size 8.5x11 paper. Can anyone help? Thanks.
    07-14-2016 03:17 PM
  15. Almeuit's Avatar
    Moved to General Help forum.
    07-15-2016 10:04 AM
  16. zuben el genubi's Avatar
    Are you getting an error message?
    I use a Samsung Printer, and Samsung Mobile app refuses to spool since under Marshmallow it can't find the external SD card. My card is media. External card in this case needs to be data so spool can be written.
    I gave up on Samsung and used Hammermill. Have not tried with Brother Laser.
    HTH
    07-17-2016 08:09 AM
  17. zuben el genubi's Avatar
    I use a Samsung Printer, and Samsung Mobile app refuses to spool since under Marshmallow it can't find the external SD card. My card is media. External card in this case needs to be data so spool can be written. You might be having a similar problem. You can also see if HP put out new printer software.
    HTH
    07-17-2016 08:10 AM
  18. oz123's Avatar
    07-19-2016 12:12 AM
  19. IMANUT46's Avatar
    I have a hp 4520 wireless printer. I can load over 10 photos and they print fine, but 1 4x6 will not print as it appears on screen. I've been at my wits end trying to get the photo to print exactly as it appears on the screen. Any suggestions? Thanks.
    07-22-2016 02:49 PM
  20. Tim1954's Avatar
    Maybe try usb cable through the computer. Could be some setting you can change on computer that you can't on your phone. I have similar issues at times with my printer and going through the laptop works...
    07-22-2016 10:53 PM
  21. IMANUT46's Avatar
    Thanks. Unfortunately, I don't have a PC. This is a standalone printer used in the wireless mode. I can live with the problem because it rarely happens. I just like to have the printer to be perfect.
    07-23-2016 05:26 AM
  22. IMANUT46's Avatar
    My Hp 4520 works normally in every mode but COPY. Is that a characteristic of the printer or do I have it on the wrong setting? Thanks.
    11-25-2016 06:22 AM
  23. anon(632115)'s Avatar
    Seems like it is slow but changing resolution and paper setting may help Solved: Copies way too slow - HP Support Forum - 5490099
    11-25-2016 07:16 AM
  24. IMANUT46's Avatar
    I have a Samsung Galaxy S5, Android Marshmallow 6.01, Verizon network. I also have a HP 4520 wireless printer. What are the steps necessary to print a web page. Please list the steps I need to follow to accomplish this. Thanks.
    04-04-2017 02:44 PM
  1. Samsung Galaxy A9 Pro Micro SD card not detected
    By idi thaangi in forum Ask a Question
    Last Post: 04-05-2017, 11:57 PM
  2. Replies: 2
    Last Post: 04-05-2017, 09:39 PM
  3. Replies: 0
    Last Post: 04-05-2017, 01:54 PM
  4. Replies: 0
    Last Post: 04-05-2017, 01:31 PM
