1. AC Question's Avatar
    My net worked perfectly fine and then it suddenly stopped. It works fine when i am in a home with my own connection set up but when i go out of the house it refuses to work. Normally if that was the case i'd used my portable tethering, but it won't work now.
    I would like to use my net when i am out of the house on my phone.
    Any idea on what is the issue?
    07-14-2016 09:36 AM
  2. altobobcat's Avatar
    It sounds like a mobile data issue. Have you checked if that is still on? Look for the green check mark.
    (Settings -> More settings -> Mobile Networks -> Mobile Data).
    Also worth checking if this isn't a data allowance issue. Finally you can check if your Access Point Settings are still correct. If not, check with your provider what those settings should be.
    (Settings -> More settings -> Mobile Networks -> Access Point Names).
    If that does't work, try a soft reset. Just pull the battery and wait 30 seconds and put it back in.
    Hope this helps!
    07-14-2016 09:59 AM
  1. Replies: 2
    Last Post: 07-24-2016, 06:09 PM
  2. Replies: 1
    Last Post: 07-15-2016, 12:57 AM
  3. Is the Nexus 5x compatible with the Samsung Gear S2?
    By AC Question in forum Nexus 5X
    Last Post: 07-14-2016, 01:37 PM
  4. Rooting Telus Galaxy S6
    By viper_crazy in forum General Carrier Discussion
    Last Post: 07-14-2016, 09:04 AM
  5. Samsung s3 camera problem
    By Bedge45 in forum Ask a Question
    Last Post: 07-14-2016, 08:37 AM
