1. heimdal's Avatar
    Samsung S5
    Android 6.0.1
    I have been using my Samsung on my home WIFI network for the last two years without a trouble.
    With no change to the phone or the router, it suddenly would no longer connect.
    I eventually did a factory reset and have still had no luck. My connection shows Saved, Secured.
    Most of the time is shows connecting, then returns to Saved, Secured.
    Occasionally it shows Authentication error.
    And occasionally is connects but then no internet.
    I have tried forgetting the network and re connecting, same issues.
    I tried resetting the network setting and same issues.
    Any suggestions appreciated.
    08-18-2016 01:10 AM
  2. hauckk's Avatar
    Samsung S5
    Android 6.0.1
    Do you have any Mac spoofing apps installed?
    08-18-2016 01:14 AM
  1. Replies: 1
    Last Post: 08-18-2016, 12:46 PM
  2. How do I unlock my Samsung Galaxy S6 active phone?
    Last Post: 08-18-2016, 04:50 AM
  3. Where did my mic go on my Samsung S5?
    Last Post: 08-18-2016, 12:15 AM
  4. Replies: 0
    Last Post: 08-18-2016, 12:12 AM
  5. samsung galaxy s5 won't stop updating software
    Last Post: 08-18-2016, 12:06 AM
