1. HernanC88's Avatar
    Hello. I just received today an refurbished S5 on T-mobile due to my LG G4 failing. I noticed that when a sound is playing(youtube,game) thru the speakers the whole cellphone vibrates. If I remove the back cover the vibration stops.
    Is this normal?
    I noticed that the opening in the speaker the one in the middle is sightly up
    Thanks
    08-20-2016 02:40 PM
  2. rahulrulz18's Avatar
    I think it's about the cover that ur using try to change the cover of the phone
    08-20-2016 03:23 PM
  3. HernanC88's Avatar
    Thanks. I'm using the one that came with the phone. I don't even have a case yet. Maybe the case will help too.
    Also I see that you can purchase a back cover that allows me to use wireless charger. Do you have any suggestions? I check on amazon and the oem is like 100$ 😑
    08-20-2016 03:27 PM
  4. HernanC88's Avatar
    Put a case on and stills the same. I don't know what's going on with this phone
    08-20-2016 11:22 PM
  5. rahulrulz18's Avatar
    U mean that u have removed the back cover and put a case on...
    The original cover should be put because of the waterproof sense that is present in the phone that vibration will come unless u put the original back cover
    08-21-2016 01:37 AM
  6. HernanC88's Avatar
    Thanks for answer. I tried both the case with the back cover and the case with out the back cover, both times I get vibration.
    The only way to get rid of the vibration is using the phone without the back cover. I took it to T-mobile and they tried with a different back cover but still the same.
    So really no one fells vibration when playing something thru the speakers but me?
    The guy at T-mobile told me is just because the speaker is on the back, hey the g4 has the speaker on the back and I didn't experience this issue.
    08-21-2016 01:08 PM
  1. Pen thickness options when screen writing gone?
    By sandra_17 in forum Samsung Galaxy Note 7
    Last Post: 09-30-2016, 12:28 AM
  2. why doesn't fast forward or rewind work when watching videos?
    Last Post: 08-20-2016, 01:02 PM
  3. Notifications when it's turned off?
    By spasell in forum Samsung Galaxy Note 7
    Last Post: 08-20-2016, 12:22 PM
  4. Calls Sound Muffled
    By reg1233 in forum Samsung Galaxy Note 7
    Last Post: 08-20-2016, 11:38 AM
  5. When will Samsung put the action memo Back on the note7?!!?
