1. wolfkillerro's Avatar
    i have a Samsung Galaxy S5 and when i call someone the screen goes black and i can't close the call if i called the wrong person
    09-12-2016 03:07 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Does the call still go through? Do you have a screen protector or a case on? If so, one of those might be interfering with the proximity sensor, which is located right next to the front-facing camera. If the proximity sensor is triggered (usually by your head, when you hold it up to your ear), it turns off the screen so that you don't inadvertently press a button with your face. But when you take it away from your ear, the screen should come back on. A dirty screen protector or ill-fitting case might make the proximity sensor think it's always up against your ear.
    can3gxw and kbrant64 like this.
    09-12-2016 03:30 PM
  1. Desktop view in stock browser problem
    By caixamagica in forum Android 4.4 KitKat
    Last Post: 09-12-2016, 04:24 PM
  2. Galaxy S4 IR blaster very short range
    By AndayWalaBurger in forum Samsung Galaxy S4
    Last Post: 09-12-2016, 03:35 PM
  3. Samsung Account.
    By bandofbrothers2112 in forum Samsung Galaxy S7 edge
    Last Post: 09-12-2016, 02:17 AM
  4. Galaxy S7 Bluetooth ruined by AT&T update to 6.0.1
    By KingDingbat in forum Samsung Galaxy S7
    Last Post: 09-12-2016, 01:33 AM
  5. Galaxy S7 Bluetooth ruined by AT&T update to 6.0.1
    By KingDingbat in forum Android 6.0 Marshmallow
    Last Post: 09-12-2016, 01:09 AM
