1. AC Question's Avatar
    I can't find my camera app settings on my galaxy s5.
    Want to turn off the camera click, and be able to zoom.help!
    09-11-2016 05:51 PM
  2. lgossin's Avatar
    Assuming you are not just having fun with us and this is a real question, running 6.01 press on the gear. In older versions it still should be a gear or the three dots menu bar. one or the other is found when you launch the camera app. Again this assumes you are using the stock app.
    Next time you post include model and at least android version
    SM-G900V
    Android 6.01
    Verizon
    09-12-2016 02:50 PM
  3. ChiefDog's Avatar
    Mine doesn't zoom. You take the picture, then zoom in in Gallery.
    SM-G900V
    Android 6.0.1
    Verizon
    09-12-2016 04:38 PM
  4. can3gxw's Avatar
    You probably cannot turn off the camera click, that is there by law in many areas to prevent people from taking "candid" shots of unsuspecting people (ie bathroom, changing rooms, etc.)
    To use the zoom feature on your camera, either use the volume controls to zoom in or out or you can also "pinch to zoom" - place two fingers (like your thumb and forefinger) together on the screen and slowly move them apart. Your camera will zoom in.
    09-14-2016 05:43 AM
  1. Hi to everybody!
    By adoriasoft in forum New to the Forums? Introduce Yourself Here!
    Last Post: 10-20-2016, 08:19 PM
  2. Why does my Pokedex only go up to Dragonair 148?
    By AC Question in forum Pokemon Go
    Last Post: 10-01-2016, 08:40 AM
  3. Weird Connection Names or Places
    By T0ASTERvan in forum Ask a Question
    Last Post: 09-15-2016, 03:25 PM
  4. why cant i change my network mode
    Last Post: 09-12-2016, 05:07 AM
