1. Ashton's Avatar
    Quick question, whenever I use wifi then turn it off my S5 (dated I know, need to upgrade) will never switch to LTE unless I restart it. It will only pick up 3G until the restart. I have tried toggling airplane mode but that doesn't work. Thoughts? Advice? Thank you!
    09-26-2016 07:04 AM
  2. B. Diddy's Avatar
    Go to Settings>Wi-fi, tap Menu>Advanced, and turn off Smart Network Switch (if you have it). Does that make a difference?
    09-26-2016 01:05 PM
  3. Ashton's Avatar
    B. Diddy, thank you for your reply. It is already switched off. So I don't think that's it. I appreciate the try though!
    09-26-2016 01:15 PM
  4. B. Diddy's Avatar
    If I recall correctly, Sprint often includes its own network management app as a preinstalled piece of bloat. Might be something like Sprint Zone. Check your Sprint branded apps, and see if there's something there that tries to manage network connections. You might have to dig into the menu of each Sprint app, because the app in question might seem like it's unrelated.
    09-26-2016 01:24 PM
  5. Ashton's Avatar
    Thanks for the advice. I don't see anything that would overtly make the signal pick up 3G and not LTE after usising wifi, but I'll fidget around a little more.
    09-26-2016 01:30 PM
  6. B. Diddy's Avatar
    Just making sure--you are still on Sprint, right? You're not using an unlocked Sprint phone on another network?
    09-26-2016 03:45 PM
  7. Ashton's Avatar
    Sorry for the delay, yes I am on Sprint with a stock Sprint Galaxy S5.
    09-27-2016 07:34 AM
  8. B. Diddy's Avatar
    Does this happen in Safe Mode as well? https://support.sprint.com/support/t...-dvc8080008prd
    09-27-2016 09:53 AM
  1. Replies: 12
    Last Post: 10-12-2016, 11:23 AM
  2. Replies: 1
    Last Post: 09-26-2016, 12:38 PM
  3. Be able to watch Networked video
    Last Post: 09-26-2016, 07:18 AM
  4. How to make the back button vibrate in Samsung galaxy j7 2016
    Last Post: 09-26-2016, 05:21 AM
  5. Replies: 1
    Last Post: 09-26-2016, 04:51 AM
