1. abdu_mka's Avatar
    Hello
    I've just got a used S5 SM-G900F Baseband Version G900FXXU1ANC7 and I have noticed that there is a large amount of delay when calling !
    the G900F is the European version, it doesn't connect to LTE but that doesn't matter to me.
    My carrier is Ultra Mobile, its a mvno that uses T-mobile network
    here is the delay shown in this clip :
    I have tried my SIM in another phone and there is no delay
    any ideas ?
    edit :
    thank you so much ironass , after the manual update there is no delay in the call audio
    10-21-2016 11:55 PM
  2. ironass's Avatar
    My first suggestion would be to update your firmware from the very old Android 4.4.2 to the latest, Android 6.0.1, for your model of phone, CSC and Product codes, as per #1.11 of 42 Galaxy S5 models - Dummies Guide to see if that helps.
    B. Diddy and abdu_mka like this.
    10-22-2016 07:48 AM
  3. abdu_mka's Avatar
    thank you so much for the great article.
    so now I want to manually update my S5, but I couldn't find the exact same version "G900FXXU1ANC7" neither here : Firmware for Samsung sm-g900f - SamMobile nor here : https://samsung-firmware.org/model/SM-G900F/page/9
    how can I know which other version is compatible ? and will the update wipe all my data ?
    thank you again @ironass
    10-22-2016 10:59 AM
  4. ironass's Avatar
    Your need to re-read #1.8 of the guide again. Look for your Product Code if there is more than 1 version.
    10-22-2016 12:49 PM
  5. abdu_mka's Avatar
    thank you , I reread it 3 times with no luck!
    I had one question , the phone info app gives the following :
    Code:
    phone model SM-G900F
    device type : klte
    product name : kltexx
    made in korea
    knos warranty void :0x0
    product code : SM-G900FZWABTU
    CSC country : UK $ IRE/ GB
    csc version G900FOXA1ANC7
    can I download this via oden ? :
    Code:
    Model Name: Galaxy S5
    Model: SM-G900F
    Country: France (SFR)
    Firmware Version: G900FXXU1CPI9
    OS: Android Marshmallow
    OS Version: 6.0.1
    Build Date: September 07,2016
    Changelist: 8538464
    PDA: G900FXXU1CPI9
    CSC: G900FSFR1CPI1
    10-22-2016 01:01 PM
  6. ironass's Avatar
    What is your Product Code?
    10-22-2016 01:16 PM
  7. abdu_mka's Avatar
    Sm-g900fzwabtu
    10-22-2016 01:53 PM
  8. ironass's Avatar
    10-22-2016 02:19 PM
  9. abdu_mka's Avatar
    its currently downloading ,
    but one last question, will it break my phone if I downloaded another region firmware ?
    10-22-2016 02:50 PM
  10. ironass's Avatar
    See the warning in #1.11 of the Dummies Guide but it will not, "break", your phone as such.
    abdu_mka likes this.
    10-22-2016 03:11 PM
  11. abdu_mka's Avatar
    10-22-2016 04:12 PM
  1. Can I PIN protect my Galaxy S5 files from desktop access?
    By MsDLT in forum Android 5.0 Lollipop
    Last Post: 12-29-2016, 12:34 AM
  2. Replies: 4
    Last Post: 11-02-2016, 10:24 AM
  3. Samsung recall notifications
    By mmsean in forum Samsung Galaxy Note 7
    Last Post: 10-26-2016, 02:49 PM
  4. best charging cable for samsung note 4
    Last Post: 10-22-2016, 02:38 AM
  5. Connecting Samsung A7 (Lollipop) to Computer.
    Last Post: 10-22-2016, 12:05 AM
