On my s5 there is a no smoking signal sign where the signal is supposed to be. Does anybody know where that is?
Thanks for the response. Is their a way to tell the difference? If it helps, I've always had this problem since I bought it. I thought I could fix it but ended up forgetting about it.That means you don't have any signal available or the mobile radios have been disabled.
Thanks for the response. I'll send a screenshot at lunch.Do you also perhaps have a little picture of an airplane? It could be in flight mode. But like SpookDroid says, all of your radios are disabled. Can you take a screenshot and post it here?
