1. cbs1507's Avatar
    On my s5 there is a no smoking signal sign where the signal is supposed to be. Does anybody know where that is?
    11-28-2016 03:32 PM
  2. SpookDroid's Avatar
    That means you don't have any signal available or the mobile radios have been disabled.
    Laura Knotek and ironass like this.
    11-28-2016 03:45 PM
  3. can3gxw's Avatar
    Do you also perhaps have a little picture of an airplane? It could be in flight mode. But like SpookDroid says, all of your radios are disabled. Can you take a screenshot and post it here?
    11-29-2016 06:23 AM
  4. cbs1507's Avatar
    Thanks for the response. Is their a way to tell the difference? If it helps, I've always had this problem since I bought it. I thought I could fix it but ended up forgetting about it.
    12-09-2016 10:24 AM
  5. cbs1507's Avatar
    Thanks for the response. I'll send a screenshot at lunch.
    12-09-2016 10:25 AM
  6. cbs1507's Avatar
    It stopped doing it. I'm not sure what caused it.
    01-26-2017 03:15 PM
  1. Voice input not working in apps on Gear S2
    Last Post: 05-13-2017, 06:02 PM
  2. Some of my Night Camera picks with my Google Pixel
    By Strife21 in forum Google Pixel & Pixel XL
    Last Post: 12-02-2016, 11:47 PM
  3. Replies: 5
    Last Post: 11-29-2016, 05:00 AM
  4. Delete moto mod notification block in drop down
    Last Post: 11-28-2016, 03:26 PM
  5. Replies: 0
    Last Post: 11-28-2016, 01:58 PM
