1. macroman64's Avatar
    Hey guys I have a Galaxy S5 klte with CyanogenMod 14.1 although I think the ROM part isn't too important as I'm using a stable build. The S5 has a 2800 mAh battery but I have horrible battery life. I get 2 hours max from a full charge. Check out the screenshot I took from GSAM Battery Monitor App which identifies wakelocks and battery drainers. It is saying that my total amount of mAh is only 450, even though it's an original 2800 mAh battery. Anyone experience something like this?
    Need help from a Senior Member on S5 Battery life!-screenshot_20170110-025529.jpg
    01-10-2017 09:00 AM
  2. Golfdriver97's Avatar
    It may be a bug in the app. Have you tried reinstalling it?
    01-10-2017 09:20 AM
  3. macroman64's Avatar
    Yes I have. Still the same.
    01-10-2017 09:57 AM
  4. Golfdriver97's Avatar
    It could also be bad battery reporting from the ROM. In which case, there may be nothing that can be done.
    01-11-2017 08:50 AM
  5. can3gxw's Avatar
    Try flashing the stock firmware for a couple of days and see what your battery life looks like then. Golfdriver is right - it could be something in the custom ROM.
    Golfdriver97 likes this.
    01-11-2017 12:17 PM
  1. Replies: 1
    Last Post: 07-07-2017, 11:40 AM
  2. Why won't my battery charge above 14%?
    Last Post: 01-10-2017, 03:06 PM
  3. New lgg5 battery drains in hour
    Last Post: 01-10-2017, 02:18 PM
  4. Battery usage 10238 causing problems on my galaxy s7
    Last Post: 01-10-2017, 08:14 AM
