1. plamenbalk's Avatar
    I tried "dr.fone" to recover data on my S5. The display is broken. I wanted to copy the data from the phones memory. The phone is(was) locked with fingerprint.
    Pressed simultaneously power + volume down + home. followed by pressing volume up.
    Now I do not see my phone from the PC. Nether blue LED is lit, nor beep comes when power-up the phone.
    Any useful tips?
    Have I lost all data forever?
    04-05-2017 08:47 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! If the phone makes no sounds or vibration when you try to power it on, then it's probably not actually powering on. There might be a problem with the battery, Power button, or motherboard. You could try replacing the battery, but it sounds like the chances of recovering any locally saved data will be low (assuming you didn't have an SD card inserted containing at least some of that data).
    Phones can fail without warning, or fall victim to accidents, so it's always a good idea to keep your important data backed up or synced somewhere on a regular basis. Never let your phone be the only place you save this data.
    04-05-2017 10:30 AM
  1. Replies: 1
    Last Post: 04-05-2017, 09:27 AM
  2. Replies: 0
    Last Post: 04-05-2017, 08:36 AM
  3. Replies: 0
    Last Post: 04-05-2017, 08:31 AM
  4. why is my s7 edge chinese swipe missing after updated
    Last Post: 04-05-2017, 08:11 AM
  5. Replies: 1
    Last Post: 04-05-2017, 07:26 AM
