1. rpnzlprnc10's Avatar
    I have verizon Galaxy S5. A week or so ago, the phone/battery started heating up whenever wifi is on, with a huge battery drain at the same time. (Actually drains the battery faster than the original charger can charge.) It will last the entire day if the wifi is left off.
    I could not find a solution, so I took a desperate leap and let the phone update to stock Marshmallow. (It didn't help.)
    I've cleared the cache, done a full reset, wiped the sd card, and updated the stock apps. I have not added any extra apps yet.
    I'm on my home wifi, and I'm ten feet from the router, so it's not signal strength. I've ALWAYS left my S5 wifi on overnight, with wifi "on while sleeping", and it rarely dropped very much by morning.
    Could this be the batteries? One battery is almost a year old. One came with the phone when I bought it last year. (I just ordered a new battery, just in case.)
    I'm an older guy, so I don't use the phone much, and (prior to the update) I only had a few extra apps on the phone. Any help would be appreciated. Thank you!
    05-10-2017 01:19 AM
  2. Tim1954's Avatar
    I'd be checking what's using the juice. In battery settings, you can go to WiFi usage and find if you have some rogue app going naughty stuff....
    05-10-2017 01:52 AM
  1. Android virus scareware on ac
    By jeffmd in forum Site Feedback & Help
    Last Post: 05-11-2017, 06:47 PM
  2. [How can I play music on my Gear 3?]
    By AC Question in forum Samsung Gear S3
    Last Post: 05-11-2017, 01:41 AM
  3. Why it wort trun on for
    Last Post: 05-10-2017, 01:54 AM
  4. Merge diffs between text files on Android?
    By Chriswaterguy in forum Android Apps
    Last Post: 05-10-2017, 12:03 AM
  5. Does anybody know how to adjust the speed and transition in slideshow?
    By Curiosalinda in forum Samsung Galaxy S8 & S8+
    Last Post: 05-09-2017, 11:27 PM
