1. Frae Guile's Avatar
    Help!
    So, I was changing the battery of my Samsung Galaxy S5 (from the old & barely holds a charge OEM to an existing Anker that holds a charge like the OEM battery, give or take a few minutes of battery life).
    While I had taken the OEM battery out to charge on the battery wall charger (slide battery in a box, out of the phone) and I was putting in the Anker battery (which had been charged on the same battery wall charger & ready to be inserted into my phone) - which is something that my phone is used to - I noticed that my phone would boot up to the brilliant colored Samsung logo.
    Then when the boot sequence got to the duller color Samsung logo (with the multicolored specks bursting from behind it) the little vibe & the menu + back back light buttons would make their little indication that the phone is going to load my home screen... But the phone would just remain showing the boot sequence with the Samsung logo (with the multicolored specks bursting from behind it) the little vibe & the menu + back back light buttons would just do their thing over & over until I remove the battery...
    I hope that I was descriptive enough to make it understandable.
    06-14-2017 11:59 PM
  2. can3gxw's Avatar
    Sorry - this is rather confusing. How a battery gets charged doesn't really matter. Whether it's in a phone or on a wall charger. What is the state of the phone when you are changing batteries? Are you leaving the phone plugged in and trying to wrestle the batteries in and out?
    - turn the phone off
    - remove the back cover
    - take out the old battery
    - insert the new battery
    - replace the back cover
    - turn the phone on
    Don't try to over complicate things. Or are you saying that your phone boot loops when the new Anker battery is in it? If you turn it off and put in the old (wimpy) battery does it boot properly?
    06-15-2017 09:51 AM
  1. Help with Sprint Galaxy S8 Plus
    By rogermd in forum Samsung Galaxy S8 & S8+
    Last Post: 06-16-2017, 11:07 PM
  2. My galaxy note edge screen is black & white
    By kashika gagneja in forum Ask a Question
    Last Post: 06-15-2017, 01:30 PM
  3. Gear s3 & Samsung health
    By 103Softail in forum Ask a Question
    Last Post: 06-15-2017, 03:01 AM
  4. THE SAMSUNG GALAXY s8+ HAS A BUILT IN TUNER FM OR NOT
    Last Post: 06-15-2017, 12:26 AM
  5. Samsung galaxy j7 sky pro tracphone
    Last Post: 06-14-2017, 08:44 PM
