1. herbeapuce's Avatar
    Hi. It seems my pictures are now saved onto the device storage. I would like to have then saved on my micro sd card , like It was before... How to go back please ? The camera app I'm using is the one that came with the phone it that matters. Thank you
    stef
    11-25-2017 09:58 AM
  2. Rukbat's Avatar
    Look in the camera app's Settings for a place to change where it's storing photos. Change it there.
    11-25-2017 02:48 PM
  3. herbeapuce's Avatar
    Hi and thanks for the help.
    I tried that but It doesn't show a place to change for my sd card... I click on Settings - More Settings - Application Manager - Camera,
    and then I have 6 new options : Storage, Data usage, Permissions, Notifications, Set as default, Battery, and 1 last option but unavailable and gray: Memory: no memory used in last 3 hours
    if I click on Storage, all I see is " Clear data'" and " Clear cash" . I don't see a place to change for sd card...
    what to do plz?
    I also check Storage and my sd card in mounted , should be working... (3.6 used of 14.8 )GB
    11-25-2017 04:30 PM
  4. herbeapuce's Avatar
    I run android 6.0.1 if that matters
    11-25-2017 04:33 PM
  1. How can I enable my SMS on my LG GPad 7.0 LTE (LG-V410)
    Last Post: 11-26-2017, 02:11 PM
  2. My cellphone is connected to wall charger but it shows usb
    Last Post: 11-25-2017, 03:20 PM
  3. Replies: 1
    Last Post: 11-25-2017, 03:14 PM
  4. Help plz lte sim card causing restart
    Last Post: 11-25-2017, 02:38 PM
  5. How to uninstall hangouts
    Last Post: 11-25-2017, 10:34 AM
