1. theycallmenick's Avatar
    I'm looking for a way to stop these annoying "Battery Critically Low" notifications. They pop up over whatever I'm doing at the moment at 15% and then 5%.
    I'm still on lollipop (by choice). I can root and disable a service or delete/edit system files if you tell me which ones but I can't seem to find which one is responsible for the popup. If you have any idea it would be greatly appreciated.
    Attached Thumbnails Battery Critically Low Notification-screenshot_2018-05-25-12-40-12-1.png
    05-25-2018 07:51 PM
  2. Golfdriver97's Avatar
    Welcome to the forums. I am honestly not sure what files to alter, but before you do, I would use a custom recovery to back up the entire ROM before messing around with root system files.
    05-25-2018 08:30 PM
  3. Moni Mihailov's Avatar
    I wanted to do the same thing a month ago and am happy to say that there is an xposed module that does just this Here's a link to it: HideBatteryLowAlert | Xposed Module Repository
    theycallmenick likes this.
    06-07-2018 09:40 AM
  4. theycallmenick's Avatar
    Wow thanks so much, exactly what I've been looking for forever!! I'm testing it out on virtualxposed, I'll see if I can use the module without root. Thanks!!
    07-09-2018 07:31 PM
  1. Best battery settings for Note 8
    By BB_PP in forum Samsung Galaxy Note 8
    Last Post: 05-27-2018, 04:12 PM
  2. Battery wit a question !ark inside
    Last Post: 05-25-2018, 07:44 PM
  3. Does it makes sense to replace battery of my Nexus 6?
    By Mahesh Abnave in forum General News & Discussion
    Last Post: 05-25-2018, 06:06 PM
  4. voice level very very very low?no further hopes
    Last Post: 05-25-2018, 12:37 PM
  5. Battery
    By Tcbemis in forum Samsung Galaxy S8 & S8+
    Last Post: 05-25-2018, 11:20 AM
