1. HumanJHawkins's Avatar
    I use a Samsung Galaxy S5 in a robot. Keeping robot and phone batteries charged is a constant issue. So I've acquired a bunch of different Micro USB3 to USB A Y-Cables in hopes of charging the phone from an on-board power bank while running the robot.
    Multiple charging sources all work fine with normal (non Y) charging cables. Yet none of several Y-Cables work to charge the phone... It doesn't even matter if the data cable is plugged in. With the phone off, I can go straight from a reliable charging station to the phone using the charging part of a Y-cable and it fails. All I get it the periodic empty battery image on the screen as it starts to attempt to charge. Then it shuts off charging as though it detected something wrong.
    Some of the cables I've tried are:
    https://www.amazon.com/gp/product/B0...cUvbUpU6560622
    https://forums.androidcentral.com/e?...token=1DZmXR3d
    Can anyone explain why this doesn't work? And more importantly, is there a solution?
    Thanks in advance.
    06-08-2019 11:14 PM
  2. methodman89's Avatar
    What is your setting for the USB when plugged in?
    06-09-2019 05:34 AM
  3. HumanJHawkins's Avatar
    If you mean what setting for data transfer, none... I can't even get it to charge plugged straight into a reliable OEM or Anker charger while using the charging side of the y-cable. Incidentally, it also fails in the same way attempting to charge from the other (data) side of the y-cables.
    06-09-2019 05:54 AM
  4. methodman89's Avatar
    Are you plugging the USB side to a USB port or a power brick with a USB output? Do you have a voltmeter?
    06-09-2019 07:26 AM
  5. Rukbat's Avatar
    Old thread, but those are all cable for power to the external device, not power to the phone. What you want is called a USB charger hub. (But any USB hub that can handle the current and is powered by external 5 Volts should be able to handle it.)
    06-23-2019 12:57 PM
  1. All my pictures won't transfer to my computer from my lg aristo 2
    Last Post: 06-08-2019, 10:49 PM
  2. Online Status - Chat Opened From Shortcut
    By rjm65 in forum Android Apps
    Last Post: 06-08-2019, 10:43 PM
  3. When i was playing a game i got something that sayed has stopped im really scared
    Last Post: 06-08-2019, 09:11 PM
  4. How to root Tablet PC Firefly M1016?
    Last Post: 06-08-2019, 06:01 PM
