1. Joe Beaudin's Avatar
    I have the new active and my brother has the exact same one, on his text message list when he sends someone an email it shows his message on the right side of the screen then when they reply it shows their reply right under his message to the left side of the screen. On my phone it shows mine on the right side then when the person replied it puts theirs above mine to the left..Is there a setting that changes that back to the normal way where their replies go under mine to the left side of the screen?
    08-19-2015 12:23 AM
  2. MattKerwin's Avatar
    Just to clarify...are you talking about texts or emails...you said both in that first line
    Sent from my SAMSUNG-SM-G890A using Tapatalk
    08-21-2015 09:05 AM
  3. Phoneguy108's Avatar
    I want to help but I'm confused on what is happening exactly.
    08-22-2015 02:22 AM
  4. Jed Perks's Avatar
    It might be a software update issue. 1 of you might have the latest update and the other doesn't.
    Jed on GS6 active
    08-30-2015 08:10 AM
  1. How do I turn off only No message left notifications?
    Last Post: 08-19-2015, 02:45 AM
  2. Replies: 1
    Last Post: 08-19-2015, 12:33 AM
  3. Replies: 1
    Last Post: 08-19-2015, 12:29 AM
  4. Can I get some help with my S6 internal antenna problem?
    By AC Question in forum Samsung Galaxy S6
    Last Post: 08-18-2015, 11:56 PM
  5. How to fix this battery percentage problem on my Galaxy Tab 3 7.0?
    By Shine Obsines in forum Hardware Hideaway
    Last Post: 08-18-2015, 08:09 PM
