ThrottleJohnny
Trusted Member
I really like tempered glass and have been using them since they became available.
I have purchased 3 different ones, 2 from ebay and 1 from Amazon. The 2 from ebay never arrived and I received full refunds.
I think what happened was the ebay sellers were buying from the same manufacturer and anticipating delivery while taking orders from consumers.
The shipment appeared to be delayed leaving a lot of us holding the bag (probably just as well). One of things that ebay sellers can do is to provide a tracking number but not necessarily ship the product. They just list the tracking number from the carriers pre-marked parcel and hold it until there is something to put inside.The they drop it off and the process moves forward. In both cases I was provided a tracking number but was unable to track due to nothing actually shipping.
I later ordered from Amazon and it eventually arrived. I think it was from the same manufacturer as the ebay sellers.
The item for the most part was a piece of junk.
- Sparkly black top and bottom bezel area, looked cheap.
- There was a lip on 2 corners where the bend was made for the edge. Kinda like the effect you get when you try to bend something thick that does not want to bend.
- Air bubbles between the layer of glass and whatever protective layer they put under the glass.
- Fit was ok around the edges but the home button and the back button, etc. cutouts did not line up.
Long story short, I don't think there is a really good tempered glass protector for the Edge Plus as of yet.
Just about every review on Amazon and ebay suggest we stay away until one of the reputable manufacturers start making them...if thy do.
There are many protectors on amazon.You can find a new one has many reviews and choose a good one.
But i think protector which can anti-blue light is great.
This protector can protect your eyes.
Currently the only screen protector for s6+ have those rubber feel which i kinda hate..
Till tempered glass arrive I may reconsider..
