08-28-2015 02:20 PM
45 12
tools
  1. Cases Blue's Avatar
    Looking for the best case for Galaxy S6 Edge+, could share your experience if you have on official case as well.
    Thanks!
    08-16-2015 07:23 PM
  2. carraser891's Avatar
    Can't go wrong with the otter box symmetry. Offers the best protection while not making your phone a brick.
    08-16-2015 08:13 PM
  3. buzzy3970's Avatar
    I 2nd the symmetry. When I got it yesterday with my gold s6 edge+ I was determined to return it because it is black and blocking the gold color from the back, but I have been getting so many compliments on the case and the phone. It's actually very well constructed and pretty simplistic so I've decided to keep it. I also was able to get it from bb for 27 dollars when it cost 50. That makes the decision much easier :-)
    08-22-2015 09:20 PM
  4. bplink95's Avatar
    Otterbox cases are monstrosities....
    BigPuddin likes this.
    08-22-2015 09:26 PM
  5. skippyg's Avatar
    Stay away from Spigen Rugged Armour resilient case. Very poor fit. Feels loose the phone actually moves inside the case. The Rinke slim crystal clear case fits perfect, even comes with a matt back cover for the glass. The beetle case by Supcase us ok. Fits better than the Spigen, feels protected but kinda bugs me that the sides aren't snug
    08-22-2015 09:42 PM
  6. yellowcanary73's Avatar
    Yes they are till you drop the phone because it's so slick and you bust the glass front and back. Then the Semmatary looks a little better. But that's what's so great about American everyone can make their own choices.
    08-22-2015 10:23 PM
  7. proof2006's Avatar
    I bought the clear casemate. Was the only one they had at the store
    08-22-2015 10:23 PM
  8. buzzy3970's Avatar
    It's a pretty minimalist case without adding much bulk. Perhaps you are thinking of typical otter box cases. It's no where near the size of the defender and thinner than the commuter. I think this is one of the best protective and sleek cases for the edge.
    Attached Thumbnails Samsung Galaxy S6 Edge+ Cases-1440309987409.jpg   Samsung Galaxy S6 Edge+ Cases-1440310024141.jpg
    08-23-2015 01:09 AM
  9. bplink95's Avatar
    I dunno... looks kind of big and cheesy to me.... I like my ringke slim case much more
    08-23-2015 02:09 AM
  10. yellowcanary73's Avatar
    Still looks cheesy.
    08-23-2015 02:35 AM
  11. bplink95's Avatar
    Still looks cheesy.
    Lol if you say so. I know you're probably upset about buying a case that is made of enough rubber to make a spare tire for a car out of... but whatever...
    08-23-2015 02:40 AM
  12. brava27's Avatar
    Spigen with kick stand ftw
    Sent from my Gorgeous S6 Edge Plus
    08-23-2015 03:07 AM
  13. mellyf's Avatar
    S View flip cover - I know it's not as protective as some covers, but I mostly want it for the screen protection. I had a tempered glass screen protector on my Note 4 and the S View flip cover...but obviously there isn't a tempered glass screen protector for this phone.
    08-23-2015 07:52 AM
  14. vientiane's Avatar
    Agree, the Ringke Slim is my pick for my S6edge and S6edge+
    sergysn and bplink95 like this.
    08-23-2015 01:44 PM
  15. HOLLYWOODANT215's Avatar
    Its a case on there? I need that case lol..i ordered to spigen slim cases,one liquid clear, other was clear with gold around it
    08-23-2015 01:57 PM
  16. buzzy3970's Avatar
    LOL that's the same thing I said. Doesn't look like there's any case on it. I've seen clear cases before and you can definitely tell there on the phone so that pic was a bit suprising. Nice if true.
    08-23-2015 02:07 PM
  17. yellowcanary73's Avatar
    How's the grip after applying this though I need something to help with grip. I had thought about the clear but worry about turning yellow.
    08-23-2015 02:07 PM
  18. buzzy3970's Avatar
    That's what I don't like about most cases(even the expensive ones like casemate) tend to look dirty. Think the Samsung clear case looks the best but hear it scratches easy.
    08-23-2015 02:23 PM
  19. stan23's Avatar
    I have the official Samsung Protective Cover. It's the most minimalist case i've ever seen, but kinda pricey at $35. The fit and finish is great, and the gold color matches perfectly. I doubt it will offer any real good protection. I like it though!
    08-23-2015 03:40 PM
  20. radyoactive's Avatar
    Where did you buy this? Verizon doesn't seem to carry it as far I've seen.
    http://stanc.net/android/IMG_4479.jpg
    http://stanc.net/android/IMG_4480.jpg
    08-23-2015 05:03 PM
  21. bplink95's Avatar
    Grip on the case is OK but better than the phone without a case... its only 10 bucks on amazon so give it a shot and see what ya think. It matches the gold on the phone pretty good so that's a plus. The best part for me though is that it doesn't show finger prints as badly as the clear cases.
    08-23-2015 07:22 PM
  22. stan23's Avatar
    I got it at the local Sprint store.
    radyoactive likes this.
    08-23-2015 07:23 PM
  23. radyoactive's Avatar
    Thanks for the info, might make a drive over.
    Sent from my VK815 using Tapatalk
    08-23-2015 07:49 PM
  24. charles777's Avatar
    It looks great... such a thin case !! Do you really trust it to protect your screen if you were to drop your phone on the pavement ?
    08-23-2015 08:43 PM
  25. Travisimo's Avatar
    I got this inexpensive one from Spigen via Amazon:
    http://www.amazon.com/Galaxy-Spigen%...cUvbUpU4630651
    I got the clear one so that it doesn't detract from the look of my Edge+. It covers the back and sides, but nothing on the front. It's minimal and doesn't really add much to the phone's thickness. If I dropped the phone and it hit the corners or back, I think it would be fine, but if I dropped it on the front screen, this wouldn't provide any protection. However, the lips above the corners might protect it a bit since it would prevent the screen from actually touching the surface if it was flat.
    At any rate, I usually go naked on all of my phones. But with this one being so expensive and a bit harder to hold because of the edge, I thought a minimal case like this would be sufficient. However, I am a little interested in the clear s-view flip cover. I'd like to try it, but I'd like some feedback on it first. I had the regular s-view flip cover for my previous S6 (not the Edge, just the standard S6) and used it whenever I traveled.
    08-23-2015 11:46 PM
45 12
  1. Regular battery swappers, preferred case?
    By Snoflo in forum Samsung Galaxy Note 4 Accessories
    Last Post: 08-17-2015, 07:02 PM
  2. Galaxy Note 5 Tempered Glass Thread
    By Cases Blue in forum Samsung Galaxy Note 5
    Last Post: 08-16-2015, 07:21 PM
  3. Galaxy Grand Prime - Stuck at Odin-what should I do?
    By Abcede Andrada in forum Ask a Question
    Last Post: 08-16-2015, 05:04 PM
