1. vamp07's Avatar
    Does anybody have any feedback on how speed compares to the standard s6 edge? I know they are identical in almost all respects but does that extra 1gig memory make any noticeable difference?
    08-20-2015 11:41 AM
  2. floss776's Avatar
    I got mine and it seems quite a lot faster actually. No lag or anything. It's really fast
    08-20-2015 02:57 PM
  3. lsmith9523's Avatar
    I had to return my regular s6 Edge due to several issues. One being the lag and the sporadic freezing of apps and keyboard. I received my S6 Edge+ yesterday and have really put it through a workout. So far, not one instance of lag or freezing up. I am using several PlayStore apps for messaging and email, and not one issue. My device is super smooth and quick and I am super happy with the battery life so far. I hope this might help.
    08-20-2015 03:22 PM
  4. vamp07's Avatar
    It does help. Makes me wonder if those same issue I am seeing in my s6 edge are just a matter of a little more memory. I wish that companies did not skimp on such trivialities. That increase in memory is a trivial increase in cost.
    Sent from my Nexus 6 using Tapatalk
    08-20-2015 04:27 PM
  5. vamp07's Avatar
    The edge+ may not overcome my main complaint of Samsung phones.
    08-21-2015 07:17 PM
  6. mj0528's Avatar
    You did see that the note was faster, right? The edge+ has the same internals as the note
    Sent from my SAMSUNG-SM-G928A using Tapatalk
    08-21-2015 10:30 PM
  7. vamp07's Avatar
    No it was not faster when it came to moving amongst apps. It fell apart. I do that all day long. The cpu tests which it won hands down is nothing I do. Who transcodes video or audio files on their phone? I had hoped that extra gig of memory would have made a difference.
    08-22-2015 05:56 AM
  8. BKlip's Avatar
    Fastest phone I've ever owned. Especially rocking Nova Launcher Prime with animations turned to "Fast as Lightning". WOW. The 4GB RAM really shows
    08-22-2015 09:42 AM
  9. skippyg's Avatar
    Cant answer for the s6e but the s6e+ is stupid fast. Ive loaded allll my content, hasnt stuttered once. Compared to my note t or htc m8 this thing is a beast.
    08-22-2015 09:50 AM
  10. jeslevine's Avatar
    Compared to the iPhone 6+, the edge+ is noticeably faster. I notice the speed difference also compared to the Note 4, where at times on the note 4 I would notice lags. Nothing like that on the edge+. In addition, the scrolling, and other operations are extremely smooth. As smooth as the IPhone 6+, if not smoother.
    Samsung has really refined the technology. I am very impressed with this phone, and I suspect the Note 5 would be similar.
    BKlip likes this.
    08-22-2015 11:48 AM
  11. radyoactive's Avatar
    The edge plus is fast, no lag or stuttering. Coming from a Nexus, I am very surprised by how well it's working so far.
    Sent from my SM-G928V using Tapatalk
    08-22-2015 12:39 PM
  12. vamp07's Avatar
    More evidence :
    http://www.androidpolice.com/2015/08...g-performance/
    08-23-2015 08:27 AM
  13. gummyjelly's Avatar
    More evidence :
    I have the s6 edge and I notice the same thing. It also messes with notifications. Sometimes I don't get certain notifications till I wake up the phone. I never had this issue with any of my other phones. Samsung really messed up this time and if this isn't fixed soon I'm sure it'll lose a lot more customers.
    08-23-2015 09:43 AM
  14. vamp07's Avatar
    I'm not sure what to make of it but it is annoying.
    Sent from my SM-G925T using Tapatalk
    08-23-2015 11:11 AM
  15. ultravisitor's Avatar
    B-b-but the spec sheet says 4GB of RAM. That automatically means the Samsung is better!!!!!
    08-23-2015 01:00 PM
  16. vamp07's Avatar
    Another great video about this problem:
    08-23-2015 06:22 PM
  17. Travisimo's Avatar
    I had the regular S6, not the S6 Edge, but the comparison should be similar. Overall, things seem pretty much on par between my recently purchased S6 Edge+ and my previous S6. I do, however, notice that Chrome tabs do not reload as often on my Edge+ compared to the S6. I haven't done any testing like in the videos, but it sure seems very snappy to me. I don't notice any lag or stutter like I have on many previous Android phones I've used. I think it feels faster than my iPhone 6+ to be honest, but of course that has a lot less RAM.
    vamp07 likes this.
    08-24-2015 12:02 AM
  18. jakeypride's Avatar
    My s6+ has matched the speed to sonic the hedgehog... and also, vamp. You got good looks.
    08-24-2015 03:57 PM
  1. Replies: 3
    Last Post: 08-21-2015, 12:15 PM
  2. Replies: 1
    Last Post: 08-20-2015, 02:15 PM
  3. Where is the Locked Screen Image stored?
    Last Post: 08-20-2015, 02:14 PM
  4. Locked out of the sprout cubby, what can I do?
    Last Post: 08-20-2015, 02:12 PM
  5. How do I unlock my Note 4 if I forgot my password?
    By AC Question in forum Samsung Galaxy Note 4
    Last Post: 08-20-2015, 11:59 AM
