Y yellowcanary73 Well-known member Jul 23, 2010 261 2 0 Visit site Aug 27, 2015 #1 Where is the quick charge switch located. Posted via the Android Central App
SpookDroid Ambassador Jul 14, 2011 19,261 518 113 Visit site Aug 27, 2015 #2 Not there anymore. It's always on now. Just depends on which charger you use.
Y yellowcanary73 Well-known member Jul 23, 2010 261 2 0 Visit site Aug 27, 2015 #3 Ok thanks. Is it supposed to show something while it's plugged in. Posted via the Android Central App
SpookDroid Ambassador Jul 14, 2011 19,261 518 113 Visit site Aug 27, 2015 #4 Yup, when you plug in your charger you get a persistent notification when you expand your notification bar that should give you an estimated time for full charge and show 'Fast Charger' if you're using one.
Blipstein Well-known member Dec 30, 2011 203 0 0 Visit site Sep 2, 2015 #5 Can you use a different USB cable with the fast charging block or is the white cable required as well? Sent from my SM-G928P using Tapatalk
