1. scottysize's Avatar
    Picked up an Edge+ off Swappa today. I have the G4, but have been very unhappy with Verizon's version of the G4. I'm on my second one and it's laggy as heck and the SOT sucks. If figured if the SOT sucks, as bad as the Sammy, I might as well try a Sammy. I've wanted to check out the edge since the first one, so this seemed like a no brainer to me. No idea which phone I'll be keeping, but I will be putting one of them up on Swappa after some evaluating. Anyway, just wanted to say hey. You'll see me around the Sammy 6 Edge+ Forums.
    bplink95 likes this.
    08-28-2015 12:54 PM
  2. bplink95's Avatar
    I think you'll love the s6e plus. Welcome aboard!
    scottysize likes this.
    08-28-2015 01:49 PM
  3. Anthony Martins Rock's Avatar
    I'm in the same boat. I am giving my Note 4 to family after Note 2 and 3. I liked them all and actually had good use for a while as I used to draw with the SPen and use it for signing PDF'S as well. My Gold 64 GB S6E+(to match my 32GB Note 4plus 32 GB SD) comes to my hands on Sept.11th. I ordered a Ringke FUSION [Crystal View] case and a leather Dbrand protection to get some cover with style for the glass back. It will vaguely hark back to the style cews of my note 4.
    Attached Thumbnails Edge+ on it's way-20150829_124023.jpg   Edge+ on it's way-screenshot_2015-08-27-10-43-21.jpg
    sergysn likes this.
    08-29-2015 03:45 PM
  4. scottysize's Avatar
    Got the phone yesterday. I don't want to jinx it, but I think I love this phone...
    09-01-2015 10:09 AM
  5. Anthony Martins Rock's Avatar
    How is it 4 days in?
    09-05-2015 04:45 AM
  6. scottysize's Avatar
    Best phone I've had for a long time. I've already sold my LG G4 and accessories. I have my new phone and love it!
    09-07-2015 06:39 PM
  7. Cwey55's Avatar
    I'm thinking about the same change, Verizon G4 to S6E+...
    Battery life is on par or better than the G4?
    No touch screen issues like G4 is having?
    Smoother OS than G4?
    Details man details!
    Before my G4 I had a GS4 and really loved that phone for it's time. I went with the G4 when the S6 came out with a piddly battery, and they have beefed up the battery on the plus, so that being the only thing that held me back before........
    Posted via the Android Central App on the LG G4
    (or the Samsung Galaxy Tab S 10.5...merica)
    09-07-2015 07:26 PM
  8. bplink95's Avatar
    Don't be another LG victim. LG phones aren't in the same class as the s6e plus.
    09-08-2015 12:12 AM
  9. epicness4G's Avatar
    As a user of the LG g4 I can honestly say that android phones are getting better and better.. The s6 edge plus is a beast. By far the best android phone I've ever used
    09-08-2015 12:30 AM
  10. scottysize's Avatar
    Just saw this post. Sorry:
    http://forums.androidcentral.com/sam...my-review.html
    09-30-2015 07:37 AM
  11. Cwey55's Avatar
    It's fine I actually went and made the switch from the G4 last week myself to the Note 5
    09-30-2015 06:38 PM
  12. scottysize's Avatar
    So, are you happy you switched?
    10-01-2015 05:50 AM
  13. Cwey55's Avatar
    Very happy. I had an S4 before I bought the G4 back in June and I loved that phone, the only thing that kept me away from the S6 was the piddly battery, and since they've beefed up the battery in the S6 edge plus and Note 5 I decided I'd had enough of the touch screen response problems on the G4.
    Really happy to be back to a Samsung where I'm more comfortable. Touchwiz looks and feels sooo much better than in years before, and the rest of the phone just blows away the G4 IMO. Only thing that could be neck and neck would be the camera I believe.
    10-01-2015 05:58 AM
  1. Lost all saved dates on my calendar, how do I get them back?
    By AC Question in forum Samsung Galaxy S5
    Last Post: 08-31-2015, 10:55 AM
  2. How do i block a contact on my Samsung Galaxy Note 4?
    By AC Question in forum Samsung Galaxy Note 4
    Last Post: 08-29-2015, 11:08 PM
  3. HTC One Mine 2 grey screen with white edge?
    Last Post: 08-28-2015, 12:26 PM
