A AC Question Aug 28, 2015 #1 What processor is in the S6 Edge+ What processor is in the S6 Edge+? Is it fast? Slow? Does it run smoothly?
mikezmac Active member Apr 8, 2015 33 0 0 Visit site Aug 29, 2015 #2 Re: What processor is in the S6 Edge+ Yes and yes. But this also depends on your usage habit and applications that you have installed. Samsung has less bloat on this column but there's still enough to make a difference however out of the box it does not impede performance. Posted via the Android Central App
