1. italygrl1's Avatar
    Does the tempered glass screen protector stick well? I know on my previous iphone 6 plus which is about the same size length wise, it lifted slightly around the sides which allowed dirt and dust to get trapped in there and i had it replaced twice and it still did it...So does anyone have that one or recommend another one that wont do that?
    09-04-2015 10:26 PM
  2. anon(92475)'s Avatar
    I don't know if the manufacturers have released a tempered glass screen protector for the S6 Edge Plus. Due to the nature of the curved screen, it appears difficulties have arisen. For now, our best bet is just a traditional screen protector.
    Also, with your previous phone, it's likely that there was dust or some other particle on the screen that caused lift.
    09-05-2015 12:59 AM
  3. schminckemd10's Avatar
    I've seen a few on amazon. I know Spigen has one release that has gotten decent reviews so far.
    Sent from my SM-G928V using Tapatalk
    09-05-2015 08:22 AM
  4. zipro's Avatar
    Spigen - really? Can't find anything on their website. I use the Spigen curved crystal one, which isn't glass, but still works extremely well and covers the entire screen
    09-05-2015 10:52 AM
  5. italygrl1's Avatar
    They have released them. I saw it in best buy. There was nothing under my other one...it was installed by att twice and they spent a good 2 minutes wiping down the screen to make sure nothing was on there before applying it. It lifted in the same spots twice. Rather annoying.
    09-05-2015 11:01 AM
  6. italygrl1's Avatar
    Thanks. I'll look into that one.
    09-05-2015 11:02 AM
  7. schminckemd10's Avatar
    I could be wrong...I think I was talking about the curved crystal one my apologies...
    09-05-2015 01:03 PM
  8. dt81's Avatar
    It's going to be hard to keep a protector on the edges with out them popping up. Only downside to the phone.
    09-05-2015 04:18 PM
  9. mortalmallard's Avatar
    Bestbuy allegedly had a tempered glass protector made by Zagg. I have yet to see one anywhere. I emailed Spigen and they have the curved crystal one as mentioned above. I asked if they were even in development for tempered glass and I was told they will jot be making them at all. Too costly was the excuse.
    Posted via Galaxy S6E+
    09-06-2015 03:13 PM
  10. BBSeattle's Avatar
    There are several different ones available on Amazon and ebay.
    09-06-2015 03:54 PM
  1. Galaxy S6 screen cracked, where can I get it fixed?
    By rkane17 in forum Ask a Question
    Last Post: 10-12-2015, 09:41 AM
  2. Brand new LG G4 with screen blemish
    By thomaslock8 in forum LG G4
    Last Post: 09-14-2015, 01:27 PM
  3. Replies: 3
    Last Post: 09-05-2015, 05:09 PM
  4. How do I remove the lock screen?
    Last Post: 09-04-2015, 11:30 PM
  5. So...about that big screen tablet....
    By Golfdriver97 in forum Alcatel Xess
    Last Post: 09-04-2015, 07:39 PM
