1. jessmags's Avatar
    Hi there - This morning I got a message for a "Urgent Update". Looks like it updated the Edge screen...? Anyone else get this?
    10-14-2015 10:25 AM
  2. skowalsky's Avatar
    What carrier if you don't mind? Haven't seen it yet on Verizon.
    Sent from my SM-G928V using Tapatalk
    10-14-2015 10:31 AM
  3. jessmags's Avatar
    TMobile - But it looks like a Samsung update...it came thru Galaxy Apps the best I can tell. Just random. And it deleted my Edge settings. Hmmm...
    10-14-2015 10:34 AM
  4. anon(607340)'s Avatar
    Got the same update this morning. Thought it was odd how they called it "urgent"
    Never seen an update say that, ever, in the history of all my Android devices.
    jessmags likes this.
    10-14-2015 10:47 AM
  5. Loud Opinion's Avatar
    The update is for the ability to change where edge icon is on your screscreen. You can move it up or down and on the left or right side of the phone now
    10-14-2015 12:23 PM
  6. anon(607340)'s Avatar
    No, it's always allowed that.
    10-14-2015 12:57 PM
  7. jessmags's Avatar
    Right?! That was why I was curious as to what it was possibly going to do to advance my phone in anyway...Weird.
    anon(607340) likes this.
    10-14-2015 01:42 PM
  8. stan23's Avatar
    I got it too. I haven't noticed much difference.
    10-14-2015 03:38 PM
  9. karriecakes1991's Avatar
    If you swipe left on edge screen it gives you apps as well as contacts. That's what it's added to mine
    10-15-2015 01:45 AM
  10. BigPuddin's Avatar
    I've always had that function.
    10-15-2015 06:12 AM
  11. jessmags's Avatar
    That has been there since the get go on the Edge Plus...Nothing new...
    10-15-2015 09:04 AM
  12. Muffius's Avatar
    Do you know how I can get back the update.
    bplink95 likes this.
    10-15-2015 09:37 AM
  13. RScottFleming's Avatar
    With the update I am now always seeing the "how to instructions"..shouldn't these be able to be dismissed?
    10-16-2015 10:42 PM
  14. Daniel Kang's Avatar
    Should be in your edge screen settings.
    I removed an app from the Edge and put it back to get rid of the instructions
    10-16-2015 11:19 PM
  1. s6 update
    By zunaer in forum Samsung Galaxy S6
    Last Post: 10-16-2015, 08:41 AM
  2. Nexus 9 Stuck during update
    By edi itelman in forum Android 6.0 Marshmallow
    Last Post: 10-16-2015, 04:26 AM
  3. How ca I update my S6 Edge Plus?
    By AC Question in forum Samsung Galaxy S6 edge+
    Last Post: 10-15-2015, 09:18 AM
  4. what is the current android update 23.21.44.en.us for?
    Last Post: 10-14-2015, 07:56 AM
