Shop Cyber Monday deals at: Amazon | Walmart | Best Buy | Dell | Samsung
  1. stressds's Avatar
    Hi there,
    Just got my first Android phone. The edge+. Loving it so far.
    I got Zooper pro thinking that I could get the below widget on my home screen. It doesn't appear to be one of their defaults and it must be custom created or third party. Does anyone know where I can find it?
    It's one of the Zooper images on the play store, so I didn't think it was a third party skin.
    Thanks!
    10-23-2015 12:05 PM
  2. Javier P's Avatar
    Hello and welcome to the forums!
    It looks like a third party skin. Take a look at this one, maybe it's based on it.
    https://forums.androidcentral.com/e?...token=t21Ny0Nv
    10-23-2015 12:44 PM
  3. jessmags's Avatar
    Hi there,
    Thanks!
    Try the Zooper Royal skin...
    10-23-2015 02:20 PM
  4. stressds's Avatar
    Thanks!
    The skin appears to have apps built into it. Must be something that can be done with zooper and something like Nova launcher?
    10-23-2015 04:20 PM
  5. Javier P's Avatar
    There are not exactly apps inside those skins. They are templates created with Zooper Widgets and shared through the Play Store. You could create them yourself with just Zooper and a lot of patience
    You can create your own widgets and import some skins just using the stock launcher and Zooper Pro. Other skins will need a custom launcher to work properly (grid size, margins, etc).
    This is my recommendation. Start creating your own widgets, it doesn't matter how simple they are. Use the stock templates or some free skins from the store and play with them. In no time you'll find that those settings are not so scary as you thought Worth the effort.
    And remember, feel free to ask if you need any help.
    10-23-2015 11:39 PM
  6. stressds's Avatar
    Thanks for the advice. I will definitely start working on it.
    Strange to be able to do so much coming from a locked down OS ☺
    Javier P likes this.
    10-24-2015 09:27 AM
  1. Should I move from lg g3 to this?
    By CellTheUltimateAndroid in forum Moto X
    Last Post: 10-30-2015, 08:18 PM
  2. Apps to SD Card
    By millerwa76 in forum Samsung Galaxy Note 4
    Last Post: 10-23-2015, 03:04 PM
  3. Replies: 1
    Last Post: 10-23-2015, 01:44 PM
  4. Replies: 1
    Last Post: 10-23-2015, 12:00 PM
  5. unable to detect sim card in samsung galaxy s4
    Last Post: 10-23-2015, 11:37 AM
