1. AC Question's Avatar
    Just bought new Edge plus and was setting it up, adding new updates etc and it is now stuck showing a picture of a green robot and a line which says, installing system update... Its been like this for 6 hours. Any ideas?
    11-10-2015 01:02 PM
  2. skid_'s Avatar
    I would have restarted by now but that's my impatience showing.
    11-10-2015 03:30 PM
  3. Matt Behnken's Avatar
    Yeah 6 hours is waay to long. Maximum 1 hour for system updates after theyre downloaded. Time to take action.
    11-10-2015 04:07 PM
  4. Phillip Pugh's Avatar
    You might want to check your WiFi I'll bet it's stopped on you
    11-10-2015 04:46 PM
  1. Charging my S6 Edge+ with a battery bank.
    By Kristopher S in forum Samsung Galaxy S6 edge+
    Last Post: 11-11-2015, 09:33 AM
  2. How much memory do I need on my Android to install and use Dropbox?
    Last Post: 11-11-2015, 12:34 AM
  3. Why does't the S Pen on my Galaxy Note Edge recognize the handwriting?
    By AC Question in forum Samsung Galaxy Note Edge
    Last Post: 11-10-2015, 04:09 PM
  4. Replies: 0
    Last Post: 11-10-2015, 12:46 PM
  5. stuck in boot loop with some additions
    By adonan1199 in forum Samsung Galaxy SIII I9300
    Last Post: 11-10-2015, 11:25 AM
