Originally Posted by
Bravfoe Try a simple restart first. Hold the power button on the right-hand side for about 2 seconds and then select restart. It will power-cycle your phone. It's worth a shot first to see if things start working again before you do a wipe/re-install.
Thank you for yr suggestion and i did restart my phone. But it seems that there is nothing change because when i tried to click the theme, still cannot browse. So i guess i have to reset eveything back then....?
