Which phone can i get; s6 edge plus on G928C or regular G928?
A
AC Question
I want to order an unlocked phone from Amazon which is the s6 Edge Plus but I have no idea which one will work in the U.S. I also want to use it on a straight talk carrier. Could anyone help me to know which will work in the U.S.?
dpham00
Moderator Team VP
Moderator
Apr 23, 2011
30,108
200
63
Personally I would get the att version. If you want to get an unlocked model then ask the seller to confirm that it is capable of working with att
19escape20
