1. AC Question's Avatar
    when you select apps edge the instructions on how to use the app is on the screen. Can the instructions be removed from the screen?
    12-18-2015 06:27 AM
  2. dpham00's Avatar
    I believe that there was an option to not show it again. Just check that box
    12-18-2015 06:53 AM
  3. Stacey Jansen's Avatar
    With the update in July 2016 it seems the instructions cannot be removed? Or can they? I would like to remove the instructions.
    07-12-2016 05:53 PM
  1. Replies: 5
    Last Post: 01-28-2016, 11:01 PM
  2. Spen misbehaving at the bottom of the screen
    By Dhanikz in forum Samsung Galaxy Note 5
    Last Post: 12-19-2015, 08:47 AM
  3. switch on keeps showing password
    Last Post: 12-18-2015, 06:56 AM
  4. Replies: 1
    Last Post: 12-18-2015, 06:21 AM
  5. app not install
    Last Post: 12-18-2015, 06:11 AM
