So hello guys i finally decided to buy the s6 edge+ but i want to ask first some question
My friend told me i should just use the spigen neo hybrid case but in the meantime i also want to have tempered glass on
The question is
1.can the case fitted compatible even if there's a tempered glass on?
2.will the tempered glass bother the screen sensivities? If yes what kind of screen protector should i use?
Please post what kind of protective screen and case you use, so i can find which will fit best for mine
Thanks in advance.
The question is
Thanks in advance.
