1. AC Question's Avatar
    bought phone off someone as a unwanted present,it was sealed when i have went to put my ee sim in its asked for a pin
    01-05-2016 08:58 AM
  2. dpham00's Avatar
    I would return it to the person that you bought it from
    01-05-2016 09:11 AM
  3. iFebby's Avatar
    You need to supply more information. Is it only asking for the pin when you put in your sim card? Is it asking for this pin regardless of a sim or not? What exactly does the pin message say? It can mean a lot of things. Perhaps it isn't carrier unlocked and requires a sim unlock code? Perhaps your sim PUK is locked? Pictures come in more handy.
    Since you said it is a 4 digit pin I will assume it is a lock screen pin. If it is you can try contacting the seller to ask if they know it. You said its sealed but it's probably just been resealed.
    01-06-2016 06:27 PM
  1. Samsung Galaxy S7 Rumors
    By Nader Salem in forum Samsung Galaxy S7
    Last Post: 02-11-2016, 04:22 PM
  2. Weird lines on screen
    By onlysamsung6 in forum Samsung Galaxy Note 5
    Last Post: 01-07-2016, 11:03 PM
  3. Did Facebook use the S6 Active as a Guinea pig?
    By GreetingsFromAP in forum Samsung Galaxy S6 active
    Last Post: 01-05-2016, 08:09 PM
  4. How to set a custom notification sound for app called Pushover?
    By Rafael Garriga in forum Ask a Question
    Last Post: 01-05-2016, 09:18 AM
