1. cheekyvirgin's Avatar
    Hi
    Can someone help please how can I disable wifi scanning. Advance setting are missing from more options in wifi menu.
    Please help
    01-24-2016 04:12 PM
  2. Lodingi's Avatar
    Go into the WiFi setting. Click on "more" in the top right corner and choose "advanced".
    01-24-2016 04:20 PM
  3. Rukbat's Avatar
    When you open the wifi page, it scans, because it's assumed that you opened the page to connect to a wifi signal - even if scanning is turned off in Wifi/Menu/Advanced. (Advanced should be in the menu for Wifi itself.)
    cheekyvirgin likes this.
    01-24-2016 04:22 PM
  4. cheekyvirgin's Avatar
    That is the problem I can't see the advance option in Galaxy s6 edge plus
    01-24-2016 07:39 PM
  5. Lodingi's Avatar
    Here's mine.what carrier are you on? I'm on Verizon.
    01-24-2016 07:43 PM
  6. cheekyvirgin's Avatar
    I'm in London on Vodafone network !! I can see all other option which you are showing in photo but advance option is missing
    01-24-2016 08:10 PM
  7. cheekyvirgin's Avatar
    Any one please advice the above
    01-25-2016 08:49 PM
  8. Lodingi's Avatar
    I assume your carrier removed that function.
    01-26-2016 01:36 PM
  9. Javier P's Avatar
    You can use the search feature in the settings just in case they are in a different place. Open the settings, tap on the magnifying glass and search for "advanced".
    Lodingi likes this.
    01-26-2016 01:38 PM
  10. skinnykins8's Avatar
    Hi,
    I'm having the same problem. did you find a solution to this as it's a battery drain I can do without?
    11-08-2016 06:06 AM
  1. How to sync Facebook contacts?
    By Jason Clishe in forum Nexus 6P
    Last Post: 12-27-2016, 09:28 AM
  2. Replies: 1
    Last Post: 01-28-2016, 10:44 AM
  3. How do I stop text messages being duplicated in email icon?
    Last Post: 01-28-2016, 10:41 AM
  4. Replies: 4
    Last Post: 01-24-2016, 05:54 PM
  5. How do I stop text messages being duplicated in email icons?
    Last Post: 01-24-2016, 03:54 PM
