1. Meriele's Avatar
    I bought my phone early in september and the battery has been good. Suddenly a week ago my phone started draining battery like crazy. I didn't install anything new before this, and I always charge it around 30% and taking out the plug when it reaches 100%.
    My phone was newly charged and on 100% at 10 pm before I went to bed, this morning (8am) it had 5% battery left. I always quit apps, the phone is on battery saving mode, and my screen brightness at the lowest or so. When i look at details of battery usage i see some apps use 1%, but nothing stands out. I'll post a picture of this later.
    Anyone got ideas why this suddenly happened? I've always been happy about the battery life..
    02-23-2016 01:33 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
    1. The main Settings>Battery screen.
    2. The fullscreen battery graph screen (which shows Awake time and Cell Signal Strength).
    3. The Screen category (to see total Screen On time).
    4. The Cell Standby category, if present (to see Time Without Signal).
    http://forums.androidcentral.com/amb...d-central.html
    02-23-2016 01:48 PM
  3. Meriele's Avatar
    Thank you, I will post it soon. How do I show the fullscreen battery graph though?
    02-25-2016 09:08 AM
  4. B. Diddy's Avatar
    This is not always available on all phone's stock battery menu. If you tap the smaller graph, that may bring up the fullscreen graph. If you don't have it, then you'd have to install a 3rd party battery app like GSam Battery Monitor.
    02-25-2016 11:20 AM
  5. tara_adele's Avatar
    my battery is fine, but my "fast charge" doesn't work at all. It hasn't for several weeks now. What gives?
    02-25-2016 01:53 PM
  6. B. Diddy's Avatar
    Hi, please create a new thread for your question, since it doesn't relate directly to the question in the original post of this thread. Thanks!
    tara_adele and kptsalami like this.
    02-25-2016 04:48 PM
  7. Frozen Corpse's Avatar
    Android System drains the most from my battery
    02-26-2016 07:51 PM
  8. dorlisa's Avatar
    Same here with the battery drain... the last few weeks it is draining like crazy. I close all apps, I have powered off...Android System is killing me for some reason.
    03-05-2016 10:40 AM
  1. How can I see what in "Android System" is using my battery
    By AC Question in forum Samsung Galaxy S6
    Last Post: 02-23-2016, 05:58 PM
  2. Replies: 1
    Last Post: 02-23-2016, 02:12 PM
  3. What is default memo app extension
    Last Post: 02-23-2016, 01:54 PM
  4. Any idea what time we can pre order online?
    By smalba in forum Samsung Galaxy S7
    Last Post: 02-23-2016, 07:20 AM
  5. How can I see what in "Android System" is using my battery
    Last Post: 02-22-2016, 08:40 PM
