1. neil74's Avatar
    Hello all,
    I have just got an S6 edge+ and am having a slight issue with the screen.
    It is very minor but I am seeing an inconsistent response when typing on the keyboard and on a certain part of the screen I am getting a very minor screen click/rattle, something you can just about hear but something you can definatley feel on certain parts of the keyboard (around the e r d f keys on standard keyboard)
    Anybody else seeing this? I am wondering if I am being over fussy but as I am within the 14 days I have the option to return it and change it maybe.
    Thanks
    Neil
    03-12-2016 03:42 AM
  2. smhism's Avatar
    I swipe to type? Also, there shouldn't be any rattle or looseness to the screen. My phone is solid. If there is, take it back and let a tech look at it, but are you sure it's not some give in your case that's causing the issue?
    neil74 likes this.
    03-12-2016 08:11 AM
  3. neil74's Avatar
    Decided to take it back and just setting up the new one which feels better.
    The old one just felt like the screen was not properly bonded across the whole area, probably nit-picky but pleased I changed it.
    03-12-2016 09:47 AM
  4. Kenya King's Avatar
    I can't hear my text messages LTE cricket
    03-28-2018 05:10 PM
  1. How much does it cost to replace a broken screen?
    By dman76 in forum Samsung Galaxy S7 edge
    Last Post: 11-15-2016, 06:57 AM
  2. Replies: 1
    Last Post: 03-25-2016, 05:50 PM
  3. Samsung GS5 SM-G900I boot loop and black screen
    Last Post: 03-12-2016, 02:41 AM
  4. i need information on phone plans while stationed in japan
    Last Post: 03-11-2016, 10:37 PM
  5. S5 screen will not sleep
    Last Post: 03-11-2016, 06:37 PM
