Welcome to Android Central! I merged a couple of your threads here.
Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
1. The main Settings>Battery screen.
2. The fullscreen battery graph screen (which shows Awake time and Cell Signal Strength).
3. The Screen category (to see total Screen On time).
4. The Cell Standby category, if present (to see Time Without Signal).
The 12% Cell Standby in your screenshot above suggests that there is some time when your cell signal is poor--this can drain your battery. Also, Verizon Cloud is using a decent amount of battery. If you never use it, I suggest clearing its cache and data, then disabling it if possible.
If you can't find a Cell Signal Strength graph in your Battery settings, then install GSam Battery Monitor.
05-05-2016 03:19 PM
