1. smhism's Avatar
    Has anyone else had an issue w/ bluetooth devices staying connected since the 6.0 upgrade (on VZW if that makes any difference). I didn't have the issue with lollipop at all. The issue is more noticeable with my car stereo, as it disconnects after about 15-30 seconds of audio playback. While messing with it last night, I noticed my Asus Zenwatch 2 is also disconnecting, but seems to be automatically reconnecting. I've tried a factory reset that appeared to work for a day and then the issue came back. I've tried clearing cache and all that jazz. I'm one step away from trying to contact VZW for a possible replacement, but trying to avoid it if I can. Any suggestions?
    05-12-2016 06:47 AM
  2. H3aTeRzz's Avatar
    Hi
    I've heard of this quite regularly after the MM update. Youre best bet would be to do a Factory Reset. But, you can try entering recovery and wiping the Cache Partition first, to see if that helps.
    Chris
    05-13-2016 07:09 AM
  3. smhism's Avatar
    Hi
    Chris
    Been there, done that. Helped for maybe two days and started again.
    H3aTeRzz likes this.
    05-14-2016 06:08 PM
  1. Replies: 3
    Last Post: 02-23-2018, 11:46 PM
  2. Weird problem with Facebook App & Browser on S7
    By Kris101 in forum Samsung Galaxy S7
    Last Post: 05-15-2016, 05:03 PM
  3. Replies: 3
    Last Post: 05-15-2016, 04:07 AM
  4. Problems with Galaxy Tab 2 charger.
    By Ritanjan Belgaonkar in forum Samsung Galaxy Tab 2
    Last Post: 05-12-2016, 10:50 PM
  5. Replies: 3
    Last Post: 05-12-2016, 10:47 PM
