1. AC Question's Avatar
    Galaxy s6 edge plus,after the software update, my battery life is awful, what can I do?
    05-12-2016 10:15 AM
  2. belodion's Avatar
    Try a Cache Partition wipe. If no go, consider a Backup & Reset. Let us know if you need advice about backing up beforehand.
    05-12-2016 11:53 AM
  3. B. Diddy's Avatar
    Welcome to Android Central! More battery stats would be helpful as well. Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
    1. The main Settings>Battery screen.
    2. The fullscreen battery graph screen (which shows Awake time and Cell Signal Strength).
    3. The Screen category (to see total Screen On time).
    4. The Cell Standby category, if present (to see Time Without Signal).
    http://forums.androidcentral.com/amb...d-central.html
    Also, here are the steps to wipe the cache: https://support.t-mobile.com/docs/DOC-21095
    05-12-2016 04:29 PM
  4. ThrottleJohnny's Avatar
    Also, something I always do after a major update is uninstall and then reinstall heavy apps, especially third party launchers. Don't ask me how but it works.
    05-17-2016 03:01 PM
  1. How many of you have the G930FD, the dual sim model?
    By Rizwan Basir in forum Samsung Galaxy S7
    Last Post: 10-28-2016, 12:51 PM
  2. Replies: 1
    Last Post: 05-12-2016, 10:23 PM
  3. HTC M8 Marshmallow update corrupted by HTC Sync
    By AC Question in forum HTC One M8
    Last Post: 05-12-2016, 04:45 PM
  4. Charging problem after update to Android 6.0
    By Juled in forum Sony Xperia Z3 Compact
    Last Post: 05-12-2016, 02:56 PM
