1. Darren Bone's Avatar
    Hi, recently when getting a text message notification it acts like I've read the message already and dissappears. If I am not with my phone that means I sometimes have a text message I don't know about, and only find out about it if I am in my inbox and see a message a don't recognise.
    It's a Samsung s6 edge plus
    Thanks
    06-16-2016 01:58 AM
  2. H3aTeRzz's Avatar
    Are you using a 3rd party message app? if so, clear its default and use native app, and see if it still occurs. If you're using native app, try clearing Cache, 2 ways, as described below.
    1. Goto>Settings> Device> Applications> Application Manager> Scroll over to ALL> Scroll down to Messages> Clear Cache.
    2. Enter Recover Mode, and wipe Cache Partition.
    Let us know if that helps!
    Chris
    06-16-2016 08:17 AM
  3. AlbertoFordo's Avatar
    Hi - I've had same issue ... I have tried some clear cache options ... will see how this goes .. thanks, Al
    12-20-2016 08:20 PM
  1. How to change the time without a phone?
    By dimkadimon in forum Samsung Gear S2
    Last Post: 10-22-2016, 08:49 PM
  2. Replies: 7
    Last Post: 07-20-2016, 07:55 PM
  3. google messanger notification wont show up on samsung led case
    By mar29020 in forum Samsung Galaxy S7 Cases & Accessories
    Last Post: 06-26-2016, 08:36 AM
  4. Replies: 0
    Last Post: 06-16-2016, 01:19 AM
  5. How do messaging/calls work on dual sim android phone?
    Last Post: 06-16-2016, 12:52 AM
