My Galaxy S6 Edge Plus keeps going into safe mode out of the blue. My volume down button can't be stuck because it goes down when I press it then comes back up and I rubbed rubbing alcohol on it just in case. I even restarted my phone and powered it down a couple of times then I tried holding down the power button and voulme down key and a screen with 5 options pop up and you pick how you want your phone to restart and it wont let me scroll them any of them it automacially goes down to the 5th option which says something about a USB and when it powers back on safe mode is still on and I havent installed ang new apps Ive been having the same apps for a while now and my phones never done this. Also it wont take screenshots by the using the home key and power button it will some days but then not other days. I just need a way to turn off safe mode. Could the volume down button be stuck internally ? It doesnt seem stuck because it goes up and down it doesnt stay down.
