1. forneyuntd's Avatar
    Hello, I have been an Apple user the last few years and have generally experienced good battery life without having to turn off a bunch of things that are useful for a smart phone. However, I have had this new phone for a few weeks now, and I am not impressed with the battery life. For everybodys' information, I have AT&T. I have had battery saver mode constantly on. I have disabled various wifi issues (always scanning, smart network switch, enhanced services) and it seems to still be a problem. I will post pictures of my battery usage data.
    08-31-2016 11:36 PM
  2. forneyuntd's Avatar
    08-31-2016 11:41 PM
  3. Tim1954's Avatar
    That looks like a reasonable run, you have an amazing powerful device with a super bright screen! Marshmallow is a bit kinder to battery life, and the S7 is better still! It also depends on how solid the network signal is in your area... I have an external battery pack on mine and it goes forever....
    09-01-2016 03:58 AM
  4. RadeonHD4250's Avatar
    How much total Uptime did you get on your iPhone?
    If it's both 14 hours, I'd say there's nothing to worry about.
    Remember, iPhone "Usage" figures and Android Screen On time aren't the same. You can't calculate Screen on Time on iPhone unless you're literally using it non-stop.
    09-04-2016 04:48 PM
  5. forneyuntd's Avatar
    Thanks for the replies. I don't remember what my total uptime was that day. Ill keep an eye out for that. If it looks normal, I guess I just need to get used to it! Thanks again
    09-07-2016 11:22 AM
  6. jj2me's Avatar
    This may or may not be your problem, but I'll relate this because I've had two separate instances of my GS6 Edge+'s battery going down more quickly than normal (and the phone heating up more), and both were due to the system app "Media Storage" acting up.
    I found the fix on Google once I saw that something called mediaserver was using a lot of juice. I see in your second screen shot that Media Server is using 4%. I don't recall if that's ok or high (mine is only using a very reasonable 0.8% after a recent "cleaning").
    To fix a runaway mediaserver in Marshmallow, go into Settings --> Applications --> Applications manager, tap "More" and select "Show system apps". Find app "Media Storage" and tap on "Storage", clear cache and clear data, Force Stop the app, and you're good to go (media knowledge will eventually be rebuilt by Android). IIRC, it has something to do with media server being confused and constantly building its database.
    09-08-2016 07:15 PM
  7. DARK Vader777's Avatar
    Please get yourself a mini external battery power pack. Monster makes a good one, also keep a car charger in car at all times. I still have the s6 edge plus and wouldn't trade my phone unless it just dies completely. The Ms's has the S7 edge, she does a little better but doesn't need to attach to a charger as often as I do. I had some of the other manufacturers cell phones at one time or another and Samsung just does it better, [as in the total experience].
    I'm no tech, guy but I think its all in Touch wiz where sams battery issues are a problem since most other manufacturers uses stock android. Suggestion, adjust your screen time on to a minimum if that helps. This was my issue, so I cut it down to 50% during the day, and at night to 20%. Find a happy spot and see how you do. Just a suggestion that's all.
    01-14-2017 03:30 PM
  8. Venu dheeraj's Avatar
    Does this battery stats are common in s6 edge plus as i heard people get neraly 5 hrs and 3.30hrs on standby (1day) does know whether my battery is bad or something is causing it
    03-05-2017 10:31 PM
  1. Replies: 4
    Last Post: 09-02-2016, 05:54 PM
  2. Gas pump corrupted my Samsung Pay
    By skatergirl in forum Samsung Galaxy Note 7
    Last Post: 09-01-2016, 02:54 PM
  3. Replies: 2
    Last Post: 09-01-2016, 09:39 AM
  4. I need a sim network unlock pin for a galaxy s6 at&t
    Last Post: 08-31-2016, 11:45 PM
  5. Replies: 0
    Last Post: 08-31-2016, 11:20 PM
