1. AlinGheaja's Avatar
    hello
    i got a new s6 edge plus
    did a factory reset,then installed my apps,got 3 ota
    i noticed the phone is a little 2 warm,and battery drains 2 fast!
    this morning at 9:00 AM the phone was at 100%, and the battery lasted 5/6 hours. sot was under 1 hour
    did again a full charge and installed gsam battery monitor
    and android os is at 31/35%
    i cant even talk at the phone,it gets hot...
    battery drains even if i dont use the phone and keep it in my pocket!
    i only have installed whatsapp and use gmail with 30 min peek
    so i flashed with other rom 6.0.1
    now android os is at 6%
    so it was fine for 2/3 hours
    then android os started using 100% !
    so i flashed a kernel
    now android os is 17%
    i got sot under 1 hour...
    most of the time the phone was just ...doing nothing
    battery lasted for 11 hours and i played a game for just only 5 min and thats it...
    also cell standby is at 24%
    screen is at 20%
    what is this ?
    09-25-2016 04:15 AM
  2. Cooler299's Avatar
    Normally such a thing should not happen especially when after changing ROM and the kernel. So I feel that your Device might have some Hardware issue and you should show it to the Shop you bought it from. Did you buy a Unlocked S6 Edge Plus?
    09-25-2016 04:21 AM
  3. AlinGheaja's Avatar
    yes its unlocked,i can use any simcard
    Attached Thumbnails new phone, android os battery drain...but why ?-screenshot_20160925-100304.jpg   new phone, android os battery drain...but why ?-screenshot_20160925-100339.jpg   new phone, android os battery drain...but why ?-screenshot_20160925-100737.jpg   new phone, android os battery drain...but why ?-screenshot_20160925-102107.jpg
    09-25-2016 04:23 AM
  4. AlinGheaja's Avatar
    turned off 4 g... cause my reception is not very good
    09-25-2016 04:49 AM
  5. AlinGheaja's Avatar
    did a full charge and let the phone sit with 4g disabled (only 2g/3g),i did 3 times reply some emails and thats it.
    is this okay ? please i need some advices
    Attached Thumbnails new phone, android os battery drain...but why ?-screenshot_20160925-173336.jpg
    09-25-2016 09:37 AM
  1. Replies: 1
    Last Post: 10-15-2016, 03:52 PM
  2. Android 6 password on startup
    Last Post: 10-13-2016, 09:31 PM
  3. Unable to install Facebook app on Android
    Last Post: 09-25-2016, 03:22 AM
  4. Replies: 0
    Last Post: 09-25-2016, 03:02 AM
  5. [Image Comparison]: LG Android Rebel LTE vs. FujiFilm XP60
    By T0ASTERvan in forum Device vs. Device Camera Shootouts
    Last Post: 09-25-2016, 02:54 AM
