1. Whenzle's Avatar
    For whatever reason at night my phone timeout will change to one second although the settings never show one second my phone will continuously turn off. It may have to do with the charger but I am on not positive. I am almost certain it is not an app.
    At this point it is annoying. I can shut off my phone (multiple times) and back on and it will still do it. On or off the charger. I have Uninstalled multiple apps turned on and off the smart stay. Changed screen timeout timeframe. Eventually it goes away.
    Anyone else having this problem??
    10-09-2016 09:47 PM
  2. Tim1954's Avatar
    Is there some night mode thing you enabled perhaps? I can't find any on mine, but you may have some custom thing installed...
    10-10-2016 12:46 AM
  3. ivor2000's Avatar
    yes - same problem but nothing to do with charging or at night. It happens all the time. Did you find a solution?
    10-26-2016 05:20 AM
  1. New S7 Edge owner after returning Note 7 today
    By Oj467 in forum Samsung Galaxy S7 edge
    Last Post: 10-16-2016, 12:04 PM
  2. Replies: 5
    Last Post: 10-12-2016, 09:58 AM
  3. Why can't I put a gallery picture on my home screen?
    Last Post: 10-10-2016, 12:47 AM
  4. The touch screen is not working.
    Last Post: 10-09-2016, 07:02 PM
