1. Majd Rihani's Avatar
    as soon as i connect to a wifi network and turn the wifi off and back on i have to type in the password again, the same as if i leave the house and come back or have my phone turned off and back on. help please
    10-21-2016 12:54 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Try wiping the cache partition: https://support.t-mobile.com/docs/DOC-21095
    10-21-2016 09:01 AM
  3. Bugwart's Avatar
    If this does not solve the problem, go to "Settings" "Wi-Fi" "More" and "Manage networks". Once you are there, click on each network that you do not need and then click forget. This will provide space for more WiFi systems.
    11-03-2016 02:42 PM
  1. My afternoon with the Verizon Pixel
    By Tomas Michiels in forum Google Pixel & Pixel XL
    Last Post: 10-21-2016, 05:06 PM
  2. COOLPIX S6 can it be left plugged in indefinetly USB port
    Last Post: 10-21-2016, 12:51 PM
  3. Replies: 0
    Last Post: 10-21-2016, 12:43 AM
  4. Replies: 0
    Last Post: 10-20-2016, 10:45 PM
  5. Why did my samsung s6 make a static/scratchy noise?
    Last Post: 10-20-2016, 10:44 PM
